jgcode
When a For Loop is Dropped Around a Node, Use Shift Registers Instead of Auto-Indexed Tunnels for Matching Scalar Inputs/Outputs
Status: Completed
Implemented in LabVIEW 2014
I think it would be nice if LabVIEW was smart enough to know that when I drop a For Loop around scalar inputs it doesn't auto-index output tunnels - but rather uses Shift Registers - for matching inputs and outputs.
The common use case for this is with the Error input/output - it annoys me how it becomes an Array output.
As it is already wired, inline and not broken, dropping a For Loop around it should not break my code!
Reference or Class inputs are other use case too - I want to pass the same thing around not create an Array
Shift registers are better than non-auto-indexed tunnels (other option) as they protect the inputs on zero iterations.
21826iFF181EE2E7ECE408
This would remove one step required for most use cases, speeding up my development experience.
Certified LabVIEW Architect * LabVIEW Champion
14 Comments
Intaris
Proven Zealot
I would suggest a slight change.  If the wires connected to the VIs being surrounded are broken (Due perhaps to an array input not being compatible with a scalar input on the VI) the for-loop should have indexing elements.  If the wires are OK, then it should insert shift registers.
There ARE some times where I want a loop with indexing inputs this way.
jgcode
Yes I totally agree with you.
The following comment was to cover that requirement:
"As it is already wired, inline and not broken, dropping a For Loop around it should not break my code!"
Intaris
Proven Zealot
Oh, OK.
Spoiler
We're losing him.  I need 200mg of Caffeine stat!
Comment to self.  Read BEFORE commenting......
jgcode
Actually I did I minor edit to include this straight after I posted - to make a more clearer point.
So you may have read the first one and commented on it whilst I was doing the edit.
What do they say.. great minds....
Anyways I couldn't let you be that hard on yourself - I'd feel terrible 🙂
Intaris
Proven Zealot
Nice of you to give me a get-out-of-jail-free avenue.
On mature recollection I think you're right.
Spoiler
I'm not going to say what you were right about, that would ruin the getaway..... Kudos either way
jgcode
Vote for this related Idea here
Convert valid Shift Register to Non-Auto-Indexed Tunnels
Jason_Harrigan
I'd state it this way: if there already exists an input of the same data type, at the exact same vertical position (same pixel count), then output should index if the input was indexed, or be a tunnel if the input was a tunnel.
NJKirchner
https://decibel.ni.com/content/groups/labview-apis/blog/2013/04/01/for-loop-pass-through-utility
This might help a little, although not everything you've dreamed of
G-Money
NI Employee (retired)
Status changed to: In Development
Darren
Proven Zealot
Status changed to: In Beta
