FixedWire
While loop stop /w error in
Status: Declined
Many times I find myself adding an OR to combine both a Stop button and the error wire. Wouldn't it be nice to have the auto wire be smart enough to know that wiring the Error to the while loop stop could accomodate both inputs.
5 Comments
PhillipBrooks
This would break the dataflow concept in my mind. The stop is a single terminal of type Boolean.
Combinational logic of different data types shouldn't be performed inside the terminal.
tst
Knight of NI Knight of NI
Knight of NI
How about if LV automatically inserted an or primitive there if you wire both into the stop terminal? LV does something similar today if you wire two DDT wires into the same place, so I'm assuming that's something NI can do relatively easily.
___________________
Try to take over the world!
FixedWire
or just right-click & have the ability to insert an OR?
rgvdh@rdf
How about if the auto wire was smart enough to put in a "unbundle by name, 'status'" & wire it up appropriately?
Darren
Proven Zealot
Status changed to: Declined
