User | Kudos |
10 | |
6 | |
6 | |
5 | |
4 |
Recently, I discovered an annoying "feature" of LabVIEW: if you limit the data entry of a floating point numeric to a maximum value with coercion enabled, entering NaN to that numeric will be coerced to the maximum that you set in the data entry dialog.
I already reported that as an unexpected behaviour, but after some more thinking, I dare to go even further and propse:
allow the blocking of NaN in floating point numeric data entry
The logic needed should not be much more than a finger exercise, as string controls already allay to discard CR/LF with the "limit to single line" property.
Sebastian
