Yamaeda
compound arithmetic switcheroo
So, in some inherited code there's lots of Compound Arithmetics where the input wires are either random or reversed from a neatness perspective.
It seems the Ctrl+click switcheroo only works on the 2 input version, and it'd be good if it worked on the larger ones. The way I see it work is either:
1. Hover over the input separator to switch those two specific inputs, which'd make a full reversal a sort of manual Bubblesort
2. Like the VI input selector, where you can select one and Ctrl+click another to switch those two.
(Atleast I cannot seem to do it in LV2017)
/Y
Qestit Systems
Certified-LabVIEW-Developer
2 Comments
RavensFan
Knight of NI
There have been several ideas posted on expanding the use of the switcheroo tool that I would call this a duplicate of one or more of them.
Here is the one that would encapsulate your idea.
Use the wiring tool to swap inputs or outputs which have been wired incorrectly
Darren
Proven Zealot
