User | Kudos |
5 | |
2 | |
2 | |
2 | |
1 |
Right now, when you wire up an array to "concatenate strings" it concatenates all the arrays strings. I'm not saying this funcitonality should go away, but I propose an option you could select from right clicking on the concatenate string function which would allow a string to be concatenated to every element in the array. Right now the only way to do this is with a for loop on the block diagarm, and it would be nice if it was handled by the node itself.
