Have you ever opened the VI Hierarchy window for a VI that calls many OpenG VIs?
If yes, you certainly wanted an option to exclude all OpenG VIs, didn't you?
The VI Hierarchy window has ONLY 3 exclusion settings (VI.lib, Globals and Type Defs), now that everyone can easily add it's own re-use code to the LabVIEW palette, we also need to be able exclude these VIs from the VI Hierarchy in order to see only the actual custom VIs called.
So please give me option to exclude user.lib!
.. And if I can even have others for Addons, instruments.lib and custom folder that would be lovely too, but user.lib is really a must!
Epictetus
