User | Kudos |
10 | |
6 | |
6 | |
5 | |
4 |
LabVIEW 2020 32bit (English), installed on Windows 10 (French).
I have noticed some small inconsistencies in the localization and formatting of the "File Dialog" and its subdialogs.
Let's say you have a "File Dialog" express VI configured in mode "File, Existing".
The main dialog and the "non-existing file" subdialog look like this:
Here I've put the parameters in [square brackets], of course it is the developer's duty to localize them.
For the rest, except for the "All Files" pattern label (which should be "Tous les fichiers" in my case), everything is correctly localized and satisfyingly formatted.
Now let's compare with a "File Dialog" express VI configured in mode "File, New".
The main dialog and the "replace existing file" subdialog look like this:
The "replace existing file" subdialog is not localized and its format is not consistent with the "non-existing file" subdialog.
For the subdialog's title, it should be the [Prompt] as well.
For the file name, it should be the short file name (and not the full path). This one is my personal preference but both subdialogs could display the full path as well, as long as it is consistent.
Raphaël.
Localization bugs not reproducible in latest version of LabVIEW.
