I would sometimes like to be able to switch the T/F cases on the select VI, the same way that you can right click a case structure and choose "make this case true/false". This would allow for less moving of things around or adding "not" before wiring the boolean up. The example here is simple, and obviously it would be easy enough to just switch things. But when you have a lot more code, it's not always quite so easy to do and can be time consuming.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-swapping-the-Select-primitive-inputs-using-the-q...
