DIAdem Idea Exchange
JuliaDawkins
Add "timer" function to SUD dialog
Status: Under Consideration
Thank you for your feedback.
We put your request to the list of possible DIAdem extensions
Greetings
Walter
Most dialog editors I've used have a "timer" function of sorts, and I would like the DIAdem SUD dialog editor to have a "timer" function.  This would allow an event to happen at a specified interval (example 1 second)
The simplest case would be to simply display the current date/time on a user dialog, and this is not possible right now without using worker objects, and I feel silly using a worker object just as a time-keeper! I would use this function often.
1 Comment
Walter_Rick
NI Employee (retired)
Status changed to: Under Consideration
Greetings
Walter
