Hello everybody,
My suggestion concern the SCRIPT tab. I think that it is necessary to implement a real automatic indentation function as you can find in most of Integrated Development Environment.
Indeed, when you write a VBS code, you have to structure your code manually while DIAdem could structure it automatically.
For instance, after an "if" and until "end if" DIAdem could insert a tabulation.
Thomas77,
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions. But because of the huge numbers of possible DIAdem extensions and the fact that just a few sponsors are supporting it, we gave this request a lower priority.
Greetings
Walter
