When I export a plot in a DIAdem report I lose the transparency that I have associated with any coloured background segments in my plots. It would be helpful if the transparency was maintained as it helps to show overlapping areas.
As a side note, I find that when I zoom out on the axis of a plot the background segments disappear when they get narrow, but still wide enough to show on screen. This can be confusing as there is no indication it is happening. Perhaps background segments could always be drawn at least 1 pixel wide.
Thank you,
Martin
As mentioned below, from Microsoft Windows 10 on the OS supports PDF with transparency. Since DIAdem 2017 you can optional select "Create PDF with Microsoft Printer" or use the PDF creater installed with DIAdem.
Greetings
Walter
