DIAdem Idea Exchange
jrk3z
Better Management of Report Pages
Status: Completed
This was implemented for DIAdem 2012
Greetings
Walter
Right now, you can only delete one page at a time (using delete or the "manage...") feature.
Why cant I just select multiple pages and "delete all".  Or in the "manage..." feature, why cant I select more than one at a time (otherwise what is the little check box for?) and delete all?
Would be very helpful to add these features
6 Comments
AndreasH_Ha
NI Employee (retired)
assuming that you use DIAdem 2011, selecting multiple pages and then deleting them should work.
jrk3z
I am using Diadem 2011
Diadem: 11.3.0f4563 TDM
USI: 1.9.0f4551
DataFinder: 3.0.0f4556
and it is not working.  I am using the CTRL to select multiple sheets, and then right clicking and clicking delete...only one sheet deletes...
what am I doing wrong?
DRock
Hi jrk3z -
The checkbox in the "Manage" dialog switches which page is displayed.
It seems that currently using CTRL to select multiple pages in the "Manage" dialog doesn't work - we'll file this feedback to R&D.
However, in the meantime, using the SHIFT key to select multiple pages in the "Manage" dialog works just fine - simply SHIFT-click to select multiple pages and then select the "Delete Worksheet" button.  Please note that this follows the typical Windows convention where SHIFT-click will select only consecutive items - I understand that this is where CTRL-click would be a valuable use case.
Derrick S.
Product Manager
NI DIAdem
AndreasH_Ha
SHIFT is used to select one consecutive block (one or more items), which is what currently supported. We'll discuss support for CTRL and with that support for deleting several blocks as new/improved feature
jrk3z
Thanks much.
I also think that it would be useful to be able to select more than one sheet without using the Manage function.  For instance, why cant I just use CTRL or SHIFT to select more than one tab from the REport View and delete from there?
Walter_Rick
Status changed to: Completed
Greetings
Walter
