DIAdem Idea Exchange
Phex
Code completion for DIAdem commands
Status: Under Consideration
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions. But because of the huge numbers of possible DIAdem extensions and the fact that just a few sponsors are supporting it, we gave this request a lower priority. Maybe we can implement these step by step.
Greetings
Walter
When entering a bult-in DIAdem command you get a tooltip hint about which command input parameter you are at. It would be great to implement code completion especially for the several enumeration variables where you need to get the script term right.
E.g. ChnOffset - When entering the value for ChnOffsetMode you should be offered "free offset", "first value offset", etc. in a pick list.
1 Comment
Walter_Rick
NI Employee (retired)
Status changed to: Under Consideration
Hello
Greetings
Walter
