DIAdem Idea Exchange
JoshRew
DIAlog Docking in Data Portal
Status: Declined
Hello
Thank you for your request. We understand your suggestion but given the age of this entry and the fact that just a few sponsors are supporting it, we have decided to decline this suggestion and prefer to develop more frequently requested features instead. We hope you understand this.
Greetings
Walter
We've suggested this in person, but thought I'd finally post it to the site.
Despite it being called the Data Portal, we'd like to have the capability of docking DIAlogs of any purpose into the data portal as new tabs alongside 'Structure' and 'List' views.
Non Modal DIAlogs tend to cover some portion of the active window, so tend to get in the way and end up being closed and re-opened by the user despite our resizing and overlapping of the Data Portal.  Allowing docking into the Data Portal would allow for convenient sizing (REPORT/VIEW tabs are already re-sized around the data portal) and movement with the application from one screen to another.
The primary example of functionality advancement for us would be our 'Page Browser', which is much like the View/Report 'manage' function, but works for both, allows filtering on both, allows for convenient rearranging of sheets to any other position, and can remain up at all times so users can simply jump to or flip to sheets without re-opening the 'manage' function or slowly tabbing/scanning through all sheets.
Obviously, it's up to you to decide the implementation...having some sort of tab manager at the very top or bottom that switches the 'Data Portal' out entirely for a 'Sheet Portal' and other custom DIAlog options & names could also work, or some other implementation entirely, but as the other tab manager already exists (but only ever contains 2 tabs), I feel would likely be less of a massive UI overhaul.
-Josh
1 Comment
Walter_Rick
NI Employee (retired)
Status changed to: Declined
Hello
Greetings
Walter
