DIAdem Idea Exchange
MaikThierer
Diadem Help - Search with *
Status: Already Implemented
Thank you for your request.
It is possible to search with wildcards.
Greetings
Walter
it is not possible to search the Diadem Help with
File*Open
or    *Chn*
or    Fi*Dlg
you always have to know the right word you search.
the possibility to search with * makes it much more easier to findes command when you only have an idea how they could be named
6 Comments
winner
NI Employee (retired)
In the search index you can use ? for one and * as wildcards for several characters. You can combine different searches with AND, OR, NOT, AND NEAR. This is possible for all Windows based help files based on *.chm
Please try
Winfried
MaikThierer
it does not work
"f*chn" give me no results
i would expact a list of commands starting with "f" and annywhere a "chn" in the name
winner
You have to use the "Search/Suchen" tab instead of the index. The "Search" make a fulltext search while the "Index" shows up only the word from the list. With "f*Chn" you will get about 10 entries in the German help.
Winfried
MaikThierer
but in the other tab you will get no command-list anyway, it´s a mix of information, command, attributes....
winner
But you can sort the results by "Position" or add "AND Befehl" and/or search "Only in title".
Walter_Rick
Status changed to: Already Implemented
Greetings
Walter
