Today I was trying to find the SCRIPT command for "Converting Numeric Channels into XY-Channels" and could not easily find it or record a script to find it. So two requests here: (1) when recording a script, output the script or have a message that says 'sorry!' and (2) update the help with the correct script functions, similar to the other channel conversion functions.
I tried to record a script, executing the ANALYSIS function "Channel Functions -> Channels <-> XY Channels", but nothing showed up in the recorded script.
Looking up the help reference for "Channels <-> XY-Channels" only shows how to display the dialog, Call SUDDlgShow("Main", ResourceDrv & "AnaChnToXYChn")
All of the other "channel conversion" help documents show how to do this in SCRIPT, for example, "Numeric Channels <-> Complex Channels" shows "
ChnConvertNumericToComplex", similar for the Numeric to Time, Waveform, etc. My proposal is below:
Script Call:
Set Group = Data.Root.ChannelGroups(1)
Set XChannel = Group.Channels(1)
Set YChannel = Group.Channels(2)
Set YChannel.XRelation = XChannel
