When I am loading multiple same-named channels into the Data Portal from a DataFinder Search Results list (after 'searching for channels'), if I load these channels into the data portal, by default they all load into the 'default' group, and because they have the same name, they are re-named inside the Data Portal with suffix numbers.
I think it would be better to create a new group in the Data Portal with the name of the group the channels belong to in their respective files, or at least provide this option.
