Rather than a channel that has a "fixed" value (numeric or string), this new "calculation channel" type would be a function of other channels. Currently, if Channel3 = Channel1 + Channel2, and then I change the values for either Channel1 or Channel2, I have to re-execute the calculation
ChnCalculate("Ch(""Channel3"") = Ch(""Channel1"") + Ch(""Channel2"")")
Now, if there was a "calculation channel" where I could define Channel 3 as "Channel1 + Channel2", I wouldn't need to perform this re-execution!
Another way to explain is to have a channel that works like Excel calculation cells. The cell calculation stays the same, and when the input cells change, the result cell is automatically updated.
I'm not sure if I explained this well, please ask for clarification if necessary.
DIAdem 2020 supports Calculation Channels as preview feature.
Calculation channels offer a simple way of creating channels using formulas. In the Data Portal, select New»Calculation Channel»Add Formula Channel from the shortcut menu and drag and drop the channels you want to use in the formula from the Data Portal into the formula area. In the formula, you can use channels, constants, numbers, and variables that reference values and channels.
If the formula channel does not provide sufficient functionality for your task, you can also use a calculation from the Calculation Manager to create calculation channels. Use the calculations in the Calculation Manager to execute mathematical operations on any channels and single values while using all functions of the calculator as well as active user commands.
Take early advantage of new DIAdem features by enabling the preview features. Preview features are new developments that will only be fully available in one of the next DIAdem versions. The user interface, the API, or the scope can still change until then. The release notes contain a list of the current preview features.
