DIAdem Idea Exchange
JoshRew
VIEW contour legend item width
Status: Declined
Hello
Thank you for your request. We understand your suggestion but given the age of this entry and the fact that just a few sponsors are supporting it, we have decided to decline this suggestion and prefer to develop more frequently requested features instead. We hope you understand this.
Greetings
Walter
Hello!
One of our users recently reported being unable to change individual VIEW 3D Contour legend item widths.  When attempting to drag the individual legend item borders in a contour, they immediately snap back to the original size.
Attempting to script this also fails to work (doesn't error, just doesn't change the size):
VIEW.ActiveSheet.ActiveArea.DisplayObj.LegendItems(1).Width = 100
2D Graphs already have this functionality, so it's more a consistency item...This is not a high priority, but a feature that would be desirable in future versions of DIAdem.
-Josh
5 Comments
Brad_Turpin
Trusted Enthusiast
Hey Josh,
Did you mean the width of the first legend property field or the width of the overall legend.  In the latter case you can use this approach:
View.ActiveSheet.ActiveArea.DisplayObj.LegendWidth = 100
Brad Turpin
DIAdem Product Support Engineer
JoshRew
Brad, each legend item (I only included the legend width setting of the first as an example).
I attached an image with an example of a 2D and 3D graphs where the legend widths are set to the same, but the individual legend item width in 3D contour legend cannot be set or even manually resized (whereas the 2D ones can).  This means that for 3D contours in VIEW, you can only display 9 character or less legend items.
Thanks!
-Josh
Brad_Turpin
Trusted Enthusiast
Hi Joshua,
You're right.  That property doesn't do a thing programmatically, and the legend field widths can't be moved manually like you said.  Good points.
Brad Turpin
MarcusP
Hi Joshua,
This looks like a bug. I will notify R&D and hopefully it gets fixed in the next version.
Marcus
Walter_Rick
NI Employee (retired)
Status changed to: Declined
Hello
Greetings
Walter
