DIAdem Idea Exchange
conzemic
data reduction on loading: add start value and data count
Status: Completed
Hi Michael,
As of DIAdem 2014 the right-click "Data Reduction..." context menu in the NAVIGATOR allows you to specify a desired index range for the channel(s) you selected to load.  Thanks for the great suggestion.
Brad Turpin
DIAdem Product Support Engineer
Hello.
The data reduction on loading could be extended to facilitate partial loading of large data sets:
Currently, it shows 'intervall width' or 'interval number' and 'reduction method (1st value, avg. min, max)'.
I'd love to have an option to define start value and data count, too. Similar to the FFT-timing dialog, where 'start/number/width' can be defined. Today, I always load the full data set, display in view, mark the relevant area and crop via 'mark data' and delete. Works ok, but when I know that I will need maybe the first 5 secs of a 10 minue measurement for one evaluation, it could be done easier, if I only load what I need.
Thank you.
Michael
2 Comments
MarcusP
Hi Michael,
Since DIAdem 2011 you can use the VBScript command DataFileLoadRed("MyDataFile.TDM","TDM","","IntervalWidth",1,1,5,395) to import only a section of your data (in this example from index 5 to index 395).
Maybe that helps until a function in the UI is available.
Marcus
Brad_Turpin
Trusted Enthusiast
Status changed to: Completed
Hi Michael,
Brad Turpin
