In the Build Specifications under Version Information one has the option of setting the Version Number of the build. Ther Version Number is of the form Major.Minor.Fix.Build.
There is an option to Auto Increment the Version Number. If this is selected the Build component of the Version Number is automatically incremented every time the specification is built.
I always use this setting since I can thereby tell the difference between builds. The major annoyance here is that although only the Build component is automatically updated all four controls are disabled and grayed when Auto Increment is selected. That means that every time I want to change the Major, Minor, or Fix part of the Version Number I have to uncheck Auto Increment, make my changes, and then re-check Auto Increment. More than once I have forgotton to re-check Auto Increment, which then screws up my numbering scheme.
Idea: When Auto Increment is selected for the Version Number, only disable and gray out the Build control. Leave the Major, Minor, and Fix controls enabled.
