This one is pretty basic...and I'm guessing there is a valid reason for the way it is. Still, I wanted to throw it out there.
Right now, if you make an object, the localized name defaults to <object>.lvclass. Therefore, when you put it on the front panel, create a constant on the block diagram, etc. it will be stored with the label <object>.lvclass:
My request is that the default name be changed to the name of the class, rather than the name of the class.lvclass. The size of the icon makes it pretty clear that we're using an object, making the extension unnecessary. Either way, this is something that I change every time I make a new object and I'm curious if the other lvoop users feel the same way.
