Reading this idea on auto-Shift-Registers, I thought of another use case that seems to be implemented wrongly. When selecting "Replace with Tunnels" on a valid (i.e. wired and not broken) Shift Register, then the tunnels should be created as Non-Auto-Indexing so that the code remains unbroken. However, if the Shift Register contains an array, then there should be the option on the right-click-menu to create either Indexed or NonIndexed terminals, as either may be wanted.
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
