GregSands
Convert valid Shift Register to Non-Auto-Indexed Tunnels
Status: Declined
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
Reading this idea on auto-Shift-Registers, I thought of another use case that seems to be implemented wrongly.  When selecting "Replace with Tunnels" on a valid (i.e. wired and not broken) Shift Register, then the tunnels should be created as Non-Auto-Indexing so that the code remains unbroken.  However, if the Shift Register contains an array, then there should be the option on the right-click-menu to create either Indexed or NonIndexed terminals, as either may be wanted.
6 Comments
tst
Knight of NI Knight of NI
Knight of NI
Frankly, I think this case is a lot less clear cut and a lot rarer than the other one.
Adding a for loop around existing code where part of it should not be changed is something I do relatively often and there LV almost always gets it wrong.
Replacing an SR with a tunnel is something that's a lot less frequent and where a non-indexed tunnel is often the valid answer. I don't feel I need a shortcut there, as it would also just blow up the menu.
___________________
Try to take over the world!
Intaris
Proven Zealot
I agree with tst here.  I don't see it as important enough to warrant inclusion.
GregSands
I thought I was saying the same as these comments, but perhaps it wasn't expressed clearly!  The main idea was that the default should be to create non-indexed tunnels -- as you say, this is the "logical" solution, and most often wanted, so it's not a matter of adding shortcuts, just changing the default behaviour to what is most intuitive.  The reason for linking it to the other idea was that I realised that if Shift Registers were automatically created when inserting a For Loop, then changing them back to tunnels was something that I'd do more often than at the moment, and I didn't want to have to deselect the auto-indexing every time.
I added the last comment once I realised that for arrays, you may not want that by default.  But I'd be more than happy to have no changes to the menus, just the default behaviour changed.
tst
Knight of NI
That I agree with - if you have an array going into a SR and you replace it with a tunnel, non-indexing should be the default and I didn't realize it isn't that way today (because I don't do this operation often). I suggest you create a new idea instead of this one where you make it clear what the behavior is today and what you want the new behavior to be. Images also help.
___________________
NJKirchner
https://decibel.ni.com/content/groups/labview-apis/blog/2013/04/01/for-loop-pass-through-utility
This might help a little, although not everything you've dreamed of
Darren
Proven Zealot
Status changed to: Declined
