X.
Creating a control/indicator from a Formula Node input/output variable should preserve this variable's name
Status: Completed
This is more of a bug report than an idea suggestion (although the boundary between both is sometimes tenuous).
When creating a Formula Node input or output variable, the name of a control or indicator created by Right-clicking the terminal is "input variable" or "output variable":
It should be named after the variable it is connected to. In the example above, I would expect "delta".
Shouldn't be difficult to do, the Mathscript node does things right:
PS: don't tell me I don't need to declare the output variables in the formula node. I know. I just created the latter for debugging purpose, which reminded me to post this overdue bug report.
6 Comments
AristosQueue (NI)
NI Employee (retired)
Filed as CAR 347958. Closing idea.
MaryH
Status changed to: Completed
X.
Trusted Enthusiast
Trusted Enthusiast
Thanks!
Andrey_Dmitriev
Trusted Enthusiast
Strange, in LabVIEW 2013 I still see this behaviour. Is this really completed, or planned for 2014 or something is wrong?
Smiley Sad
crossrulz
Knight of NI
I don't think this has actually been done.  This has been documented as a CAR since this is more of a bug than a change request.  The status of this idea should really be "Declined" instead of "Completed".
GCentral
X.
Trusted Enthusiast
Trusted Enthusiast
It is not completed and I hope it is not declined. But like you can only kudo ideas, I guess you can only categorize ideas as "Completed", "Declined", "In Development" "In Beta" or "Duplicate".
Being able to vote for the idea (by not closing it) might - in principle - keep the pressure on NI. Not.
