This is more of a bug report than an idea suggestion (although the boundary between both is sometimes tenuous).
When creating a Formula Node input or output variable, the name of a control or indicator created by Right-clicking the terminal is "input variable" or "output variable":
It should be named after the variable it is connected to. In the example above, I would expect "delta".
Shouldn't be difficult to do, the Mathscript node does things right:
PS: don't tell me I don't need to declare the output variables in the formula node. I know. I just created the latter for debugging purpose, which reminded me to post this overdue bug report.
