I was using quick-drop today and I had an idea to yet further augment the insane efficient of this tool...
A) Display the Quick-Drop dialog box when a letter or number is pressed on the block diagram instead of CTRL+Space. Letters and numbers don't do anything unless you're typing in a comment, constant, etc. This would eliminate two keys from the process.
and
B) Select the best Quick-Drop match with a right-click while the dialog box is open. The right mouse button does nothing in this dialog box at the moment. This would eliminate the motion to the Enter key and stay over the letters / numbers with my left hand.
SO...
If I have "g" assigned to "Greater?", all I would need to do is press "g" and right-click. BAM. DONE. The original method would be CTRL+Space, then press "g", then press Enter, and then I'd have to move my hand back to CTRL+Space for the next combo.
I know it seems small, but I use Quick-Drop HUNDREDS of times a day. What do you think?
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
