Marc Blumentritt
Expand config.lvlib: get path of config file from config reference
Status: Declined
Moved to CAR database. CAR#235635
Create a VI, which allows to get the config file path from the config reference.
Marc
CLD
10 Comments
JackDunaway
Trusted Enthusiast
Or rather, expand the functionality of the "Refnum to Path" primitive.
I just tried to wire this primitive to a Config File Ref, and it does not create a broken wire, it always seems to return <Not a Path>. This could be an issue that needs to be addressed separately (?).
AristosQueue (NI)
NI Employee (retired)
Jack: CAR 235635 filed for the Refnum To Path primitive issue.
Technico
@ AQ: The "Refnum to Path" results in a broken wire when connecting a TDMS refnum
Message Edited by Technico on 06-16-2010 01:18 AM
AristosQueue (NI)
Technico: Noted.
G-Money
Status changed to: Completed
Marc Blumentritt
What is the CAR database and where can I read about CAR#235635?
CLD
G-Money
I am changing the status from Completed to Declined because Completed should only be ideas that R&D see on Idea Exchange, actively developed on it based on the idea here, and it was added to the product.
G-Money
Marc,
The CAR database is NI's internal tool that keeps track of bugs reported by customers so we can actively work on them. Unfortunately there isn't an external facing way for you to check up on it's status. The readme file that comes out with each new product release will have a list of CARs (Corrective Action Request) that was fixed in that release and this is the best way to determine when the bug is fixed. While your idea definitely points out an issue with LabVIEW, a CAR is the more appropriate action for us to take on this.
G-Money
Status changed to: Declined
leif h
I have been assigned to adapt a LabVIEW 8.2 application to LabVIEW 2011.
The 8.2 application uses "Config Data Get File Path.vi", that is included in the 8.2 "config.llb" library.
In the 2011 "config.llb", it is no longer available, so the application does not work in LabVIEW 2011.
 I have seen that there is a "Get File Path.vi" that seems to do the job, but it also seems to be available only from within the library.
Can anybody please help me find a solution to this problem?
Leif
