User | Kudos |
5 | |
3 | |
3 | |
2 | |
2 |
There's a common convention in LabVIEW where if a control is not a required input, you place the default value in parentheses:
For the most part this make sense and is useful when calling VIs, but there is one place where it's really annoying:
We know there's no error by default. I suggest that NI simply remove this. This can be done today by going to <vi.lib>\errclust.llb and modifying the control, but that's annoying to do with every installation.
I would even go so far as to say that NI should write a VI which will go through vi.lib and remove the text from all the existing VIs. I doubt this would have any backward compatibility issues, because I think the only place where those would be relevant is if someone is calling a VI in vi.lib dynamically AND setting the error in value, and frankly, those people deserve to be punished.
Available in LabVIEW NXG 1.0. The error terminal names for nodes are now 'error in' and 'error out'.
