User | Kudos |
10 | |
6 | |
6 | |
5 | |
4 |
Let's assume I must do three (or more) operations in sequence (in the following example, instrument control operations)
There are several ways to force execution order. But I want to use a flat sequence (for example, in order to insert timing VIs).
My goal is the following:
There are at least two problems:
- if I try to include the first VI on a flat sequence, other VI's wires will appear "beneath" the sequence (not throug)
- If I add a frame afterwards, there's no way to include existing code without redrawing the wires.
I propose two possible solutions:
- Create a flat sequence for each VI, and add the possibily to combine them in a single sequence afterwards.
- Create a flat sequence for the first VI, add a frame after, and allow the "drag edge" action to "fagocitate" existing code (instead of pushing existing code to the right, or extending above the code if AUTO-GROVE is disabled).
Anyway, when there's a wire running beneath a structure, the possibility to "let him through the structure" (by adding tunnels) should be added as well.
Any idea that has received less than 10 kudos within 10 years after posting will be automatically declined.
