Somil
Measure the time of execution
Hi
Certainly, every body tries to evaluate a vi in terms of performance. This includes the time which a particular code takes to run. We have to use the tick cout vi in order to determine the time of execution.
How about adding an additional button in the  toolbar itself which measures the time taken by a particular code to execute? Smiley Happy
This can certainly be a good feature in LabVIEW!!!
Somil Gautam
Think Weird
9 Comments
tst
Knight of NI Knight of NI
Knight of NI
You can use the timed sequence for this - it has an output called Frame Duration.
Also, if you use the JKI RCF, I posted a plugin here which will wrap a piece of code in a timing structure.
___________________
Try to take over the world!
Somil
Is it like this that for measuring the execution time,  everytime i will have to use a timed sequence?
Somil Gautam
Think Weird
tst
Knight of NI
No. You can use the standard sequence with the tick count primitives (which is what the link in my post pointed to), but the timed sequence requires less setup.
In any case, if you want to time a block of code, you're going to have to tell it when you want to start and end and the most generic solution is a structure. The only relevant structure really is a sequence structure.
___________________
Somil
Helpful !!!!!!
Somil Gautam
Think Weird
Knight of NI
This has already been suggested here: Allow a quick "Timing Probe" for Timing Metrics.
Somil
Oh, i didnt know that.
Somil Gautam
Think Weird
Mark_Yedinak
Trusted Enthusiast
If you are looking to time the processing time for an entire VI you can use the profiler.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
JackDunaway
Trusted Enthusiast
Also, check out Yair's popular Community Nugget about timing.
G-Money
NI Employee (retired)
