Good day forum
Proposal: to have a option to check for properties that can behaviourally change during deployment.
Case: recently built a VI that is called from TestStand and encountered error during execution in the end-user PC (installed with TS and LV RTEs) and found this property that can behave differently in RTE environment. Retested in LabVIEW through application build but received no incompatibility or possible error notifications. Installer builds (with automatically select recommended installers checked) also did not indicate the necessity of having the Development System environment.
A optional check on this type of property could be nice.
Thank you 🙂
