Today, the management of error codes is a little bit complicated. (Error code file to include in executable properties ... )
It could be intersting to add a new entry to a project which could list all custom errors only available to the project.
This file or project property could be associated with the project as a source code !
How many time you'll get an old application ... without all files ... And error code file is a source file. So the error code file should be located near the project ...
Or best inside the project !
The best way to manage the custom errors would be to edit them in the project properties like "conditionnal disable symbols".
Simplifying the error code management will reduce the none managed errors ( The famous 488 error !!!! which i hate ! )
