manu.NET
Project error code files ...
Status: New
Today, the management of error codes is a little bit complicated. (Error code file to include in executable properties ... )
It could be intersting to add a new entry to a project which could list all custom errors only available to the project.
This file or project property could be associated with the project as a source code !
How many time you'll get an old application ... without all files ... And error code file is a source file. So the error code file should be located near the project ...
Or best inside the project !
The best way to manage the custom errors would be to edit them in the project properties like "conditionnal disable symbols".
Simplifying the error code management will reduce the none managed errors ( The famous 488 error !!!! which i hate ! )
Manu.net
6 Comments
Doug
Great idea!
It seems like such an easy thing to do too.  Just make the Custom Error Codes file path selectable in the Project, rather than hard-coded to ..\User.lib\
silmaril
Yes! This really is a great idea for people working with multiple and large projects!
Let me just add that I don't like to put anything into user.lib or instr.lib (not even 3rd party instrument drivers).
If something is needed inside a project, it should be part of the project directory and managed in source code control.
All the things NI likes us to put into user.lib and instr.lib are some kind of user data which don't belong under the Windows Program Files directory (a normal user shouldn't have write access there anyway).
felipefoz
With all new LabVIEW projects working towards a project based development, I think this idea should be more alive than ever.
Late, but I left my kudos here.
Ajay_MV
I agree. The error codes need to be local to the project and controllable via SCM
Ajay MV
mthheitor
Yes, we need different ways to manage the custom error codes
joerg.hampel
Here at HSE we prefer creating constant VIs for error codes. That way, error codes are maintained together with the libraries they were defined for and we can programmatically find and document them (Antidoc already does that for DQMH modules and .lvlibs).
We've been working on an internal (i.e. commercial) tool that helps with managing error codes. Here's a brief description: https://dokuwiki.hampel-soft.com/code/commercial/hse-error-code-helper/overview
PS: The error code files are not that relevant for our own way of working, but I can see a benefit of providing them as part of our installable reuse libraries so that 3rd party users can look up the error definitions in the Explain Error window.
DQMH® (Developer Experience that makes you smile )
