User | Kudos |
5 | |
3 | |
3 | |
2 | |
2 |
I have seen similar suggestions on tabbed clusters, but what I would like to be able to do is add a tab control to a cluster. For example, I would to pass via the connector pane a tab control with different controls on the different pages (by putting the tab control in a cluster to pass as a single data type). Basically, I have several ways of defining the data and use the tab control to choose which way the data is defined. This saves a bunch of window space and is much more intuitive to look at versus having a cluster of every control with a separate enum.
What I want (showing all three pages):
What I currently have to do:
I suggest that the tab control would look like an enumeration as a data structure within the cluster . Thus, put the tab control in a cluster and when you unbundle it, it would like like the unbundle of the second example.
I looked at using XControls to separate the display from the data, but I found out you can't wire an XControl to the connector panel!
