If we select some code and try to copy it to the front panel, nothing happens of course because the code has no meaning on the front panel.
However, we can paste that same code into many other applications (e.g. MS Paint) and it turns into an image. We can immediately copy that image and paste it to the front panel. I often use this for forum examples, e.g. here.
Why can't we eliminate the middleman????
We should be able to paste code directly to the front panel and it will simply turn into an image of the code!
We should even be able to simply drag code from the BD to the FP for the same effect.
This could even be useful during code reworking. We could temporarily paste a picture of the old code to the FP so we can better remember what was connected where while we make modifications.
(It could even turn into a snippet so we can drag it back and it turns into code, but a plain image is probably sufficient)
