As discussed here and here, it is annoying that a Value Property Node of a typedef is not typed properly (*).
Related or not, as discussed here, it is annoying that when you try to create a typedef constant for a typedef control, you have to actually do that from the Terminal. And the problem is compounded byt the fact that you cannot access the terminal from a Property Node! It is grayed out. A specificity of typedefs. All other Controls/Indicators terminals can be access by right-clicking any of their property nodes.
Thanks for reading.
Tested in LV 2011
(*) definitely not new in LV 2011
