User | Kudos |
7 | |
6 | |
4 | |
4 | |
2 |
I posted this in the discussion forums here, but after forming my thoughts, I realize that it is really a suggestion for product improvement, so I'm cross posting here.
In short, I would like the ADCS toolkit to use Frame In/Out Queue Sessions instead of Frame In/Out Stream Sessions when running on XNET hardware (or at least make that an option). This would enable the separate use of a Frame In Stream Session to log all of the CAN traffic on a port.
This was recently made possible for the ECU M&C toolkit in version 2.3, and I think the same concept should be extended to the ADCS toolkit.
A cursory test of ADCS 1.1.1 suggests that this may already be an undocumented feature of the toolkit, but there are some subtle bugs that may need to be worked out for this to be fully supported.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
