I was trying to isolate two versions of code by putting them in a "Version 2.0" and "Version 2.1" library, and then (at run time) calling the appropriate analysis routine from the "correct" Library based on values stored in the data. In the process, I managed to corrupt the .lvlib file, and (because I didn't know better) tried to "correct" this error by deleting the .lvlib file.
What that left me with was a file, formerly in the library, that I couldn't open without LabVIEW complaining bitterly that it could not find "Untitled Library 1.lvlib". In addition, I could not even create a new Project and "Add" anything without such an error message appearing.
After a few weeks of struggle and consultation with NI Support, we found part of the problem -- the file that was formerly in the (now-deleted) Library had "hooks" to the Library embedded in its header. Since this is in a proprietary (NI) binary format, I would like NI to provide a utility that can open a VI (or anything else that can be embedded in a Library) and remove the "hooks" that associate it with a particular .lvlib. If this function were a LabVIEW function, then the user could write a utility using this function to apply it to a file, a folder, or a directory tree, as the situation warranted. This would allow large VIs "corrupted" by being placed in, and improperly removed from, a Library to be returned to a stable, non-Library, state.
Functionality already present in LabVIEW
