patibandla
selecting multiple elements in the array to delete
Status: New
Problem:
I faced to delete multiple elements form the array which is having 20 steps.
solution:
if able to select multiple elements by holding the shift key we can delete selected items 1 time and can insert 1 time.
7 Comments
PaulG.
I'm surprised we can't do this already.
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
X.
Trusted Enthusiast
Trusted Enthusiast
We can't even do it on a control!
donkdonk
Array editing in general should be improved. Similar suggestions on improving array editing have been done before on this forum.
I personally would like to have array editing similar to editing in excel:
Easily select a range or area (for 2-d arrays) by mouse or shift-arrow then delete/insert/shift rows/columns etcetera.
Copy pasting to/from excel would then also be more intuitive (at least for those using excel).
pauldavey
You can edit arrays by right-clicking on the array indexes and choosing "start selection", "end selection". Choose "show selection" to see a blue framing of all selected cells.  Change the indexes to specify where to start/end selection.
donkdonk
"You can edit arrays by right-clicking on the array indexes and choosing "start selection", "end selection". "
This is exactly what I think is a cumbersome procedure. As said before, excel does a much better job in selecting/deleting/inserting.
Manzolli
It would be nice to have ability to select multiple elements in a easier way, then do many operations like copy, cut, delete, paste, etc. Kudos!
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
billko
Proven Zealot
I just ran into this issue myself.  Kudos given!
Bill
CLD
(Mid-Level minion.)
