We've been banging on about the advantages of using proper design techniques in LabVIEW for well over 10 years and I'm not about to stop now. To start my blogging career I thought it might be a good idea to describe what we mean by good design.
A good design....
I also want to establish some separation between the tools and the design.
The key is if you can make a bad design with it, then it is a tool. A tool is used to express your design. So saying you are a good designer because you use OOP is like saying I'm a good architect because I use concrete!
I would also like to put some distance between declarations not backed up by evidence .
The following are common statements.
It is better to use a technique knowing the consequences than not knowing the risks at all.
On the coming subjects I really want a discussion, there are elements to these ideas that will need properly exploring.
For many decades the following ideas have contributed most to the design arena (in whatever language you use). Get a feeling for these concepts and you'll make your programming life less stressful, guaranteed!
Coupling
http://en.wikipedia.org/wiki/Coupling_%28computer_programming%29
Example: Using globals is bad because global memory is very tight coupling. If any subroutine can access and change data at any time it doesn't take a genius to work out that this will make the code hard to understand.
Cohesion
http://en.wikipedia.org/wiki/Cohesion_%28computer_science%29
Example: Keep all like functionality encapsulated into one VI. The encapsulation needs to be done at block diagram level, using references, lvlibs, classes is not as helpful.
Take the following Use Case.
An instrument is used throughout a test system, it has 50 functions that can be set by sending text commands via a serial port. A non-cohesive method is to send commands at each point in the test via VISA. The implications of this design choice (and believe me we've seen it) is that if you change the instrument you will have to find every VISA call related to this instrument and change the text.
Information Hiding
http://en.wikipedia.org/wiki/Information_hiding
Hiding the implementation detail behind a defined interface allows changes to be made internally without affecting the rest of your code. I've come to the conclusion that this is probably the most important thing to understand.
Things I'm going to be discussing in future blogs (as and when I get the time and energy)
Lots of Love
Steve Watts
Sales pitch....I'm always interested in really really easy work with large budgets
Steve
Opportunity to learn from experienced developers / entrepeneurs (Fab,Joerg and Brian amongst them):
DSH Pragmatic Software Development Workshop
