Make an option to have REPORT auto-scaling work like VIEW:
VIEW updates the Y-Axis range to be appropriate for the presently visible data when Y-Axis auto-scaling is on and a manual X-Axis range is selected.
REPORT presently maintains the Y-Axis scale of the entire Y-Axis channel's range regardless of X-Axis range selection.
The current behavior requires the user to manually scale both the X and Y axis, when manually selecting an X-Axis range on a highly variable data set. In my case, I'm setting the X-Axis range in a script (last 30 days), but will now also have to determine and set a manual Y-Axis range for the 30 day window of X-Axis values.
I put "Optional" in the description because sometimes the current behavior is desired (if the user wishes to maintain a consistent Y-Axis at all times).
-Josh
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
