DIAdem Idea Exchange
JoshRew
Optional REPORT Y-Axis auto-scaling for manual X-Axis range
Status: Under Consideration
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
Make an option to have REPORT auto-scaling work like VIEW:
VIEW updates the Y-Axis range to be appropriate for the presently visible data when Y-Axis auto-scaling is on and a manual X-Axis range is selected.
REPORT presently maintains the Y-Axis scale of the entire Y-Axis channel's range regardless of X-Axis range selection.
The current behavior requires the user to manually scale both the X and Y axis, when manually selecting an X-Axis range on a highly variable data set.  In my case, I'm setting the X-Axis range in a script (last 30 days), but will now also have to determine and set a manual Y-Axis range for the 30 day window of X-Axis values.
I put "Optional" in the description because sometimes the current behavior is desired (if the user wishes to maintain a consistent Y-Axis at all times).
-Josh
7 Comments
Missy_Conley
Having report autoscale like view does would save a massive amount of time when reviewing data over a specific time period.
-Missy
shevonv
 -JoshRew - How did you manage to set the x axis range in a script? Do you have something you can share? I have daily set points that I look at and for the first few days its fine. After about 50 days, it gets pretty hard to look at data since the x range keeps getting bigger. I would like it to just plot only the last 20 days of data.
JoshRew
Shevonv, the report TDR is loaded as part of a script that also updates the graphs.  Here's most of the relevant code, which uses the X-Channel TimeStampAbsolute to determine 30 days from the most recent test and set the X-Axis where necessary:
Dim XMaxDate
Dim NumDays
Dim oCurrObj, o2DAxisXScaling
Dim i, j
NumDays = 30
if cno("TimeStampAbsolute") > 0 then
   XMaxDate = cmax("TimeStampAbsolute") 'Get the most recent test's date
   XMaxDate = cdate(str(XMaxDate,"#mm/dd/yyyy")) + 1 'Chop off the time and add a day to offset from the end of the graph
   For i = 1 to Report.Sheets.Count 'Loop through all sheets
     For j = 1 to Report.Sheets(i).Objects.Count 'Loop through all sheet objects
       Set oCurrObj = Report.Sheets(i).Objects(j)
       Select Case oCurrObj.ObjectType
       Case eReportObject2DAxisSystem 'Update X-Axis scaling on all 2D Axis objects, regardless of name (no other objects)
         '------------------- 2DAxisXScaling ------------------------------
         Set o2DAxisXScaling = oCurrObj.XAxis.Scaling
          o2DAxisXScaling.AutoScalingType = eAxisAutoScalingManual
          o2DAxisXScaling.Type = e2DXScalingDateTime
          o2DAxisXScaling.Begin = Val(XMaxDate - NumDays)
           o2DAxisXScaling.Origin = o2DAxisXScaling.Begin
           o2DAxisXScaling.End = Val(XMaxDate)
        End Select
      Next 'j
    Next 'i
end if
shevonv
Thanks JoshRew for sharing. I'd certainly be able to modify my code to incorporate this as well when I launch my script.
Walter_Rick
NI Employee (retired)
Status changed to: Under Consideration
Hello
Greetings
Walter
JuliaDawkins
Wonderful request! It is confusing to users when this feature works in VIEW but REPORT has different behavior. Seems like a low-effort charge!
panta1978
That would be a feature I would really appreciate! The unexpected behaviour of DIAdem when I limit x-range is giving me a bad time. Any workaround is complicated and not so effective.
