When working in DIAdem SCRIPT, it is often necessary to work on more than one file at once. The way this is implemented at the moment is with tabs:
However, it can be quite tedious to switch back and forth between 2 scripts for things like copy/pasting, comparing code or simply editing code on 2 files concurrently.
My suggestion would be for a SCRIPT editor with split screen functionality, roughly like this:
With many users working with widescreens today, this would better make use of screen real-estate.
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions. But because of the huge numbers of possible DIAdem extensions, we gave this request a lower priority.
Greetings
Walter
