P@Anand
Array function - corrections
Status: New
I wonder whether it has been posted before.
When creating an Indicator out of Index array, Replace Array subset and Insert into array the indicator are not inline with the output terminal. We cannot call that as a bug, I propose it here so that it may be corrected in future.
14 Comments
crossrulz
Knight of NI
My OCD says I must give you Kudos
GCentral
P@Anand
Trusted Enthusiast
Whats OCD? 🙂
crossrulz
Knight of NI
Obsessive Compulsive Disorder
I don't really have the disorder.  It's just a saying about me being really picky when it comes to diagrams looking nice.
GCentral
Darin.K
Trusted Enthusiast
Not a duplicate, but my preferred solution to this problem is here:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Put-a-created-control-indicator-constant-on-the-cursor...
Basically there could be Avagadro's number of these ideas since the algorithm screws up more often than it gets it right.
PaulG.
Kudos. After 15+ yrs of LV programming this behavior is still annoying.
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
Jokelnice
Completely agree.
Kudos .....
Ing. Jonathan E. Cruz Ortiz
ENERGÍA PROACTIVA S.A.S
Cel : (+57) 3173669343 - (+57) 3124451894
joaopam
Yeah I agree with this idea.
I spend lots of time to align everything on the block diagram and this behavior is frustrating.
Kudos...
Mondoni
Yamaeda
Proven Zealot
You could actually add Build Array to that list. Since the output currently is centered you never get a straight wire if done in a case, as you often do. Either the pass through case or the build case gets a bent wire.
The simple solution would be to have the Array out at top right position.
/Y
Qestit Systems
Certified-LabVIEW-Developer
elset191
( idea and duplicate )
Tim Elsey
Certified LabVIEW Architect
Yamaeda
Proven Zealot
Thanks Elset, other idea Kudoed. 🙂
Qestit Systems
