tobyscott
Increase loop or case size including nodes
Sometimes I would like to shift some nodes inside an event or other structure. Currently I have to either redraw the structure to include the nodes (have to reset tunnel/shift register assignments etc, doesn't work for cases) or move all the nodes inside the structure and rewire everything.
Proposed solution: resizing the structure with shift pressed includes the nodes inside the structure, much like if you draw the structure around the nodes in the first place. Also this feature would be super helpful for adding frames in a flat sequence, just shift and drag yourself a new frame with everything inside.
3 Comments
crossrulz
Knight of NI
Duplicate: Allow structure resize to capture code not just move it
GCentral
tobyscott
Thanks, I looked but couldn't find anything
Darren
Proven Zealot
