Sometimes I would like to shift some nodes inside an event or other structure. Currently I have to either redraw the structure to include the nodes (have to reset tunnel/shift register assignments etc, doesn't work for cases) or move all the nodes inside the structure and rewire everything.
Proposed solution: resizing the structure with shift pressed includes the nodes inside the structure, much like if you draw the structure around the nodes in the first place. Also this feature would be super helpful for adding frames in a flat sequence, just shift and drag yourself a new frame with everything inside.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-structure-resize-to-capture-code-not-just-move-i...
