The Daily CLAD
Community Browser
回复: CLAD2017 - Fundamentals - String Manipulation 5 of 5
SercoSteveB
What is Output String following execution of the VI?
Comments
crossrulz
Knight of NI
C
GCentral
ChristineM
I can never get these snippets to be code in Labview.  I read that I need to drag them to the desktop and then into the block diagram (I'm using Labview Full 2018); however, it always just appears as a picture.  Can anyone help?
crossrulz
Knight of NI
ChristineM,
First click on the picture.  There is a "download" button in the overlay that comes up.  After downloading, you can drag it onto your block diagram.  Due note that this snippet was created with LabVIEW 2019.  Therefore you will need at least LabVIEW 2019 for the snippet to turn into code.
GCentral
abasak86
C.
wayrider
C
Mani@2019
A
skian
C
CA-Pioneer
C.
It is a sub string match function, if match, the last part of string would be to output. Since the array is set to 0, that means sub string 'Steve' is selected, it is matched and the last part 'LikesLabView' is the final output. So, if array select is '1', the output should be 'SteveLabVIEW'
yangmy20201230
I have tried, and it is really effective; Further, I would like to ask how to use LabVIEW to create this png file and publish it on the forum? Thank you very much~
