DIAdem Idea Exchange
Naity
Allowing to drag and drop channel in the pocket calculator
Status: Completed
Feature was released with DIAdem 2014
I noticed channels can be dragged and drop everywhere but in the calculator. Ths channel list is quite OK when havin a few channel in the Data portal but becomes fast ´a waste of time on bigger projects. Allowing to drag channel in ot would make it faster to use and also a bit more user friendly.
______________
Florian Abry
Inside Sales Engineer, NI Germany
4 Comments
Brad_Turpin
Trusted Enthusiast
Hi Naity,
This is absolutely something we want to do.  In the meantime, have you checked out the Calculation Manager as an alternative approach to doing interactive calculations?  You can drag&drop to the input and output fields in the configuration dialog of each Calculation in the Calculation Manager.  It also gives you an easy way to save and distribute Calculations and link Calculations together.
Ideally, we'd like the simple Channel Calculator to have many of the benefits of the more complicated Calculation Manager, including but not limited to dragging and dropping data channels.
Brad Turpin
DIAdem Product Support Engineer
Jackie_B
NI Employee (retired)
Hi all,
A similar feature that would be useful is the ability to drag individual cells for single value calculations into the VIEW tab calculator. For example, instead of typing ChD(1,1)-ChD(1,2) to subtract two cell values, simple drag these cells into the calculator.
Jackie B
Applications Engineer
DAQ Product Marketing Engineer
dietfons
Status changed to: Under Consideration
dietfons
Status changed to: Completed
