The Daily CLAD
Community Browser
Re: CLAD2017 - Fundamentals - String Manipulation 3 of 5
SercoSteveB
What are the contents of String Array Out following execution of the VI?
Comments
crossrulz
Knight of NI
C
GCentral
Krishna_kp
Answer is C.
Loop will execute for 4 times, so at last iteration one empty string will add to output array.
TommyInglethorpe
C
abasak86
Option C. The While Loop will execute four times.
skian
C
istan0227
C
CA-Pioneer
C.  If it is For Loop, the result should be B. While loop would search the next "" at the time 4 then get -1(no match) to stop the loop in this case.
